You are here: PSPad forum > Bug report / Hlášení chyb > Re: Highlighter ignores some entries
#1 Highlighter ignores some entries
Posted by: fyurisich | Date: 2021-05-25 16:13 | IP: IP Logged
The user highlighter is not working properly because it ignores some entries.
If you delete previous entries then the ignored entries change.
This happens with entries in the 4 tabs.
Tested with 5.0.7 (638)
#2 Re: Highlighter ignores some entries
Posted by: pspad | Date: 2021-05-25 16:16 | IP: IP Logged
To be honest I don't understand. What do you mean by "ignoring entries"?
#3 Re: Highlighter ignores some entries
Posted by: fyurisich | Date: 2021-07-08 00:41 | IP: IP Logged
For example, it ignores keywords starting with _ (please note that _ is added to "Allow chars in keywords". Also, if I insert new keywords, some old ones stop being highlighted. Example: 1drv.ms
#4 Re: Highlighter ignores some entries
Posted by: pspad | Date: 2021-07-08 03:13 | IP: IP Logged
Send me your highlighter definition + some source example to support mail
#5 Re: Highlighter ignores some entries
Posted by: pspad | Date: 2021-07-08 11:08 | IP: IP Logged
fyurisich:
I found problem with string sort and Locale settings.
It should be fixed in the next build
#6 Re: Highlighter ignores some entries
Posted by: fyurisich | Date: 2021-07-09 15:26 | IP: IP Logged
Excellent!
Thank you for your hard work.
