You are here: PSPad forum > Bug report / Hlášení chyb > Re: exception occurs very often when comparing 2 files
Posted by: LGP | Date: 2021-05-17 07:02 | IP: IP Logged
I must submit this. Since I am on the 64 version, an exception violation etc occurs
sometimes (too many times in fact).
Today the context is this one: last version 5.06 just loaded - comparison between a file which is on a server and a local version of this file.
The serveur file is open through filezilla;
after comparison (with the integrated pspad tool) I close the tab where this comparison has been exposed. At this moment the exception occurs.
I am obliged to close PSPad and to reopen it. Sometimes, I must shut down the PC.
Sorry for not having noted the specific message in extenso.
Next time, I will take a copy of it.
Hope this will help to maintain this editor in good shape.
Best regards
Luc
Posted by: pspad | Date: 2021-05-17 07:49 | IP: IP Logged
What PSpad version do you use?
5.0.5 and 5.0.6 has problems with open/close files. 5.0.7 (available in PSpad developer forum) hsould be much more stable
Edited 1 time(s). Last edit at 2021-05-21 11:33 by pspad.
Posted by: ramoncar | Date: 2021-09-04 17:31 | IP: IP Logged
I've very similar problem, in my case both files are opened from local filesystem.
The sequence (in my case) to reproduce the problem is:
. Open file A
. TextDiff (from Windows Explorer context menu) file B
. Close comparison tab
. Close file B
. TextDiff (from Windows Explorer context menu) file C (this compares A vs C)
. Close comparison tab --> Access violation !!
In short, the error appears when closing the second comparison tab. (The second file comparison maybe with B again, the error happens the same).
In this case, PSPad closes without bringing the option to email the stack dump.
It shows the following two error messages, and terminates.
Version is 5.0.6 (589) 64b
Just to say, this is not new, my previous version 5.0.3 32b also exposed the problem, but I didn't perform a precise sequence determination until now.
Kind regards
Application Error
Exception EAccessViolation in module PSPad.exe at 0000000000A91C60.
Access violation at address 0000000000E91C60 in module 'PSPad.exe'. Execution of address 0000000000E91C60.
Aceptar
PSPad.exe - Error de la aplicación
La instrucción en 0x0000000000E91C60 hace referencia a la memoria en 0x0000000000E91C60. La memoria no se pudo written.
Haga clic en Aceptar para finalizar este programa
Aceptar
Posted by: pspad | Date: 2021-09-05 06:07 | IP: IP Logged
I need whole exception logs to recognize what is wrong.
Visit developer forum, download current 5.0.7 build and replace existing files. It should help with your problem.
Posted by: ramoncar | Date: 2021-09-05 14:08 | IP: IP Logged
Indeed developer version does not expose the same behaviour.
Thanks a lot !
