You are here: PSPad forum > Bug report / Hlášení chyb > Re: CTRL + S does not move to the folder with the file
#1 CTRL + S does not move to the folder with the file
Posted by: Piotr | Date: 2021-05-10 10:50 | IP: IP Logged
For some time (I do not know from which version) saving a file (ctrl + s) does not move it to the folder where the file is located.
It was a very useful feature. Will he come back?
Thanks
PSPad 5.0.7 (625)
#2 Re: CTRL + S does not move to the folder with the file
Posted by: pspad | Date: 2021-05-10 11:15 | IP: IP Logged
In the program settings / Files and dirs check option wat will suit for you:
()Remember last directory
or
()Same as active document
I think the secod option will fit to you
#3 Re: CTRL + S does not move to the folder with the file
Posted by: Piotr | Date: 2021-05-10 12:24 | IP: IP Logged
thank you for the quick reply
Unfortunately it does not work.
I ran the program again but it doesn't work
#4 Re: CTRL + S does not move to the folder with the file
Posted by: pspad | Date: 2021-05-10 12:37 | IP: IP Logged
Do you mean File explorer in PSpad left panel?
From next build, it will synchronize when you will have set second option
()Same as active file
and file explorer will be active
Edited 1 time(s). Last edit at 2021-05-10 12:58 by pspad.
#5 Re: CTRL + S does not move to the folder with the file
Posted by: Piotr | Date: 2021-05-10 12:53 | IP: IP Logged
Yes
My english is from google translator. Sorry...
Edited 1 time(s). Last edit at 2021-05-10 12:54 by Piotr.
#6 Re: CTRL + S does not move to the folder with the file
Posted by: Piotr | Date: 2021-05-10 13:12 | IP: IP Logged
Ok, thanks!
smiling smiley
#7 Re: CTRL + S does not move to the folder with the file
Posted by: Piotr | Date: 2021-05-15 16:47 | IP: IP Logged
5.0.7 (625)
"Automatic synchronization of File explorer after file save in case when Program settings / Files and dirs is set directory as Active file and File explorer is active."
Its not working sad smiley
#8 Re: CTRL + S does not move to the folder with the file
Posted by: pspad | Date: 2021-05-15 17:06 | IP: IP Logged
Just tested with 629 build and it works for me
Conditions:
1. file explorer in the left panel is selected
2. Program settings / Files and dirs
Directory as active file is selected
File must be modified, else you can't save it. For test purposes add and delete space and save your file.
#9 Re: CTRL + S does not move to the folder with the file
Posted by: Piotr | Date: 2021-05-15 17:18 | IP: IP Logged
It works!
Thank you very much!
Regards from Skierniewice (Poland)
