You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPAD.INI
Re: PSPAD.INI
#1 PSPAD.INI is still not read and evaluated !
Posted by: SF | Date: 2021-05-06 10:59 | IP: IP Logged
The in PSPAD.ini saved configuration is still not read and evaluated in this Update-Version 5.0.7(623)
I think the last working PSPAD-Version was 5.0.6(589), but i use now 5.0.7(586) is more stable...
Edited 3 time(s). Last edit at 2021-05-06 11:04 by SF.
#2 Re: PSPAD.INI
Posted by: pspad | Date: 2021-05-06 11:16 | IP: IP Logged
I solved similar problem with another user. Problem was corrupted ini file
Copy pspad.ini somewhere and open it.
Correct lines are:
Variable=value
Or
[section name]
If you see any other lines forms, delete it, save it and return back to pspad.
#3 Re: PSPAD.INI
Posted by: SF | Date: 2021-05-06 11:28 | IP: IP Logged
you are right it did something. But it was a lot of the wrong lines ...
#4 Re: PSPAD.INI
Posted by: SF | Date: 2021-05-06 11:36 | IP: IP Logged
but why my old version PSPAD 5.0.7(586) don't have any problems with this corrupt configuration ?
#5 Re: PSPAD.INI
Posted by: pspad | Date: 2021-05-06 11:40 | IP: IP Logged
I changed library for work with ini files. The new is much faster. I guess the old one ignored wrong lines.
Your INI can be corrupted long time.
I will try to investigate library sources and if it will be possible, i will modify it to handle wrong lines.
#6 Re: PSPAD.INI
Posted by: pspad | Date: 2021-05-06 12:25 | IP: IP Logged
I found a problem in reading. Next build will be able handle "corrupted" PSpad.ini too
