You are here: PSPad forum > Bug report / Hlášení chyb > Two bugs in 5.0.6(589)
#1 Two bugs in 5.0.6(589)
Posted by: akiuni | Date: 2021-05-04 08:08 | IP: IP Logged
First, thank you for that very nice and free program !
I'm facing two frequent bugs with pspad 5.0.6(589) :
- Very frequent EAccessViolation
- stranges caracters sometimes are added in the files..
Please consider the following informations :
- You will find below the latest EAccessViolation.
- I'm using pspad as simple windows user (no administrator rights)
- Here are the changes I made in my settings :
- Program : unchecked "ESC to Exit Program"
- Program : checked Don't change toolbar icon size when monitor DPI is changed
- Files and Dirs : New Default = UNIX Shell script
- Files and Dirs : New File format : UNIX
- Files and Dirs : DEfault CP for files opening : Unicode UTF-8 BOM (65001)
Exception class:
Exception address:
Stack list, generated 04/05/2021 09:52:29
Thank you for your time to report this issue!
Please don't post exception report into the forum.
Send it to my support address (see Help > About).
And please add a short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
- What did you do: ....<accurate step-by-step instructions here>..
- How did you do: by keyboard press, by menu, context menu, macro
- You had expected to get: ....
- But you got instead: .....
Thank you.
Program : C:\Program Files\PSPad editor\PSPad.exe 5.0.6 (589)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i7-10850H CPU @ 2.70GHz, 2720 MHz MMX
Display : 1920x1200 pixels, 32 bpp PPI: 120
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-05-04 09:50 by Stefan.
#2 Re: Two bugs in 5.0.6(589)
Posted by: akiuni | Date: 2021-05-04 08:20 | IP: IP Logged
I've forgot to say that I'm using a corporate Anvitirus Software (that I can't disable.)
Another Crash :
Exception description:
Exception class:
Exception address:
Stack list, generated 04/05/2021 10:18:26
Thank you.
Skin : Windows
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_L90977550"
Edited 2 time(s). Last edit at 2021-05-04 09:48 by Stefan.
#3 Re: Two bugs in 5.0.6(589)
Posted by: akiuni | Date: 2021-05-10 07:18 | IP: IP Logged
I'm sorry for the spam, I've sent the other bugs by email as requested.
If somebody is facing the same problems, I have uninstalled the 64bit version of PSPad and installed the 32bit version. And all the bugs disappeared !
That may be a workaround in the meanwhile.
Best regards
Julien
smiling smiley
Edited 2 time(s). Last edit at 2021-05-10 07:19 by akiuni.
#4 Re: Two bugs in 5.0.6(589)
Posted by: pspad | Date: 2021-05-10 08:30 | IP: IP Logged
I think 5.0.7 builds (developer forum) are already stable enough
