You are here: PSPad forum > Bug report / Hlášení chyb > EAccessViolation 000000000052EF09
#1 EAccessViolation 000000000052EF09
Posted by: DaweSlayer | Date: 2021-04-27 19:36 | IP: IP Logged
I have many bugs like this, it almost stops with previous version, it occured i think when i opened a file and pressed F3 to find previously used regexp "require|include"
Exception description:
Exception class:
Exception address:
Stack list, generated 27. 4. 2021 19:24:37
Please don't post exception report into forum.
Send it to my support address (see Help > About).
And please add short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
Thank you.
Program : C:\Programy\PSPad editor\PSPad.exe 5.0.7 (600)
System : Windows 8.1 Professional x64, Version: 6.3, Build: 2580,
Processor: AMD, AMD FX(tm)-9370 Eight-Core Processor , 4266 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-28 13:38 by Stefan.
#2 Re: EAccessViolation 000000000052EF09
Posted by: DaweSlayer | Date: 2021-04-28 02:25 | IP: IP Logged
This time i diffed files, clicked from diff tab on a second file and was selecting line of code (click shift+home). Not the first time in a similar situation, after switching from a fresh diff file tab.
Exception class:
Exception address:
Stack list, generated 28. 4. 2021 1:53:53
Thank you.
Processor: AMD, AMD FX(tm)-9370 Eight-Core Processor , 4280 MHz MMX
Skin : Windows
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-28 13:39 by Stefan.
#3 Re: EAccessViolation 000000000052EF09
Posted by: DaweSlayer | Date: 2021-04-28 02:27 | IP: IP Logged
And now it's happening just by pressing shift (only in that second file)
Thank you.
Edited 1 time(s). Last edit at 2021-04-28 13:37 by Stefan.
