You are here: PSPad forum > Bug report / Hlášení chyb > Alt+F, C crash
Posted by: Quin | Date: 2021-04-25 09:51 | IP: IP Logged
When I type alt+F, C to close the current tab, the program closes without error (even if there are other tabs open, even unsaved other tabs).
After this crash, when I try to run the program again via Start Menu or just opening an associated text file, the program doesn't open; still no error. I only see the "thinking circle" appear momentarily. After restart, the program works normally until I use alt+F, C again.
Perhaps related or not, also when I type alt+F, S to save the file, the "File" menu is still highlighted. I have to press "alt" twice to un-highlight it and place the cursor back into the document. It functions normally when I press alt, F, S in sequence.
Version:
5.0.6 (589)
64bit
Windows 10 (updated as far as I know)
This is a new computer and I have only been using PSPad on it for a week.
Posted by: pspad | Date: 2021-04-25 10:02 | IP: IP Logged
This problem was fixed in 5.0.7 builds in PSPad developer forum.
But wait please for today's new build, it brings another fixes.
