You are here: PSPad forum > Bug report / Hlášení chyb > exception opening an existing file in new instance
#1 exception opening an existing file in new instance
Posted by: John Huijsing | Date: 2021-04-21 04:59 | IP: IP Logged
Exception description:
tried to open a file in a new instance
Access violation at address 0000000000557ADE in module 'PSPad.exe'. Read of address 00000000000000FF.
Exception address:
Stack list, generated 21/04/2021 12:56:59
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.7 (597)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2200 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-27 11:27 by Stefan.
