You are here: PSPad forum > Bug report / Hlášení chyb > Re: Perl syntax Highlighter issue
Posted by: John Huijsing | Date: 2021-04-20 09:04 | IP: IP Logged
This time in the correct forum
#This ok
my $var1 = qq{
more lines of text
#This does not display correctly the q an left brace are not displayed
my $var2 = q{
some more lines of text
Change the the syntax to txt and it is displayed correctly
John
Posted by: pspad | Date: 2021-04-20 09:11 | IP: IP Logged
This problem was fixed already, fix will be available in the next build.
Problem was joined with q() and qq() function implementation into hihglighter.
I was told that q function can be followed with ( and { bracket.
I changed q function hihglighting with ( brackets only.
