You are here: PSPad forum > Bug report / Hlášení chyb > Re: [CRASH] Access Violation
Posted by: Locutus | Date: 2021-04-17 11:52 | IP: IP Logged
Crash occurs from time to time to me when working with xml or lua files, mostly when switching between tabs in pspad. I've been using PSPad for 6+ years, crash has always followed me over win 7, 8, 10 and 2 computers and 1 laptop with different hardware. Always AccessViolation.
Feel free to email me if you need sth. specific.
Exception description:
Exception address:
Stack list, generated 17/04/2021 13:40:23
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Program Files\PSPad editor\PSPad.exe 5.0.6 (589)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62, Processor: Intel, Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3700 MHz MMX
Display : 2560x1440 pixels, 32 bpp PPI: 96
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 2 time(s). Last edit at 2021-04-27 09:29 by Stefan.
Posted by: Locutus | Date: 2021-04-18 11:24 | IP: IP Logged
This one on opening a new xml file:
Exception address:
Stack list, generated 18/04/2021 13:24:19
Skin : Windows
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-27 09:28 by Stefan.
Posted by: Locutus | Date: 2021-06-06 10:29 | IP: IP Logged
Mhh, whenever I try to send such reports via mail I get
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of
its recipients. This is a permanent error.
The following address failed:
support@pspad.com:
SMTP error from remote server for RCPT TO command, host: a.mx.pspad.com (81.0.235.44) reason: 550 sorry, permanent envelope failure (#5.7.1)
Posted by: pspad | Date: 2021-06-06 10:35 | IP: IP Logged
Locutus:Mhh, whenever I try to send such reports via mail I getThis message was created automatically by mail delivery software.
its recipients. This is a permanent error.The following address failed:
''.phorum_html_encode('support@pspad.com').'':
Address ''.phorum_html_encode('support@pspad.com').'' is functional. It looks like the problem is with software/sender you send message. Mail envelope is created by sender side, not by receiver side.
Posted by: Locutus | Date: 2021-08-29 11:29 | IP: IP Logged
New log (sorry, I can't send Mail, you seem to be blacklisted)
Exception description: Crash when opening an xml file from search results
Edited 1 time(s). Last edit at 2021-08-29 11:31 by Locutus.
Posted by: pspad | Date: 2021-08-30 12:17 | IP: IP Logged
Visit PSPad forum and download the latest build 5.0.7 from PSPad
developer forum: www.pspad.com
Replace existing files with content of archive.
