You are here: PSPad forum > Bug report / Hlášení chyb > Convert ANSI file to UTF-8
Posted by: mile77 | Date: 2021-04-10 14:17 | IP: IP Logged
I open a PHP file in ANSI format and change the encoding to UTF-8 no BOM, then save it.
When I reopen it, it is still in the old format.
I also tried the batch conversion, but the result is the same.
mile77
Posted by: vbr | Date: 2021-04-10 14:46 | IP: IP Logged
mile77:Hi,
mile77
are there some specific characters other than ASCII - basic Latin, numbers etc.?
There normally a detection for encoding, which should recognise utf-8, but for those "lower" characters without accents etc. the file is the same even in different encodings.
Do you get get some corrupted text due to the bad encoding onreopening the file or is it just the displayed encoding in the satutsbar?
I believe, PSPad can keep the previously selected encoding for a given file, according to the settings:
Settings: Files and Dirs: [x ] Remember File state
hth,
