You are here: PSPad forum > Bug report / Hlášení chyb > Re: strange 俰؃ character after the last update
Goto Page: Previous1 2 3
#21 Re: strange 俰؃ character after the last update
Posted by: sirajch | Date: 2021-07-27 10:09 | IP: IP Logged
Same issues here.
Version: 5.0.6 (589)
In some files (*.php) when I wrote php code it's randomly appears this char: 㰐ܺ
As I can say, it seems, that it appears before or after brackets '{' in IF STATEMENTS, but not on the current line. I'm writing on line 2500 for example, but the char appears on line 200 for example too.
I use this settings: Html multihighligter, DOS, Unicode UTF-8 no BOM (65001)
#22 Re: strange 俰؃ character after the last update
Posted by: pspad | Date: 2021-07-27 11:15 | IP: IP Logged
Download current 5.0.7 build please
#23 Re: strange 俰؃ character after the last update
Posted by: sirajch | Date: 2021-07-29 07:55 | IP: IP Logged
downloaded, seems it works right, thx
#24 Re: strange 俰؃ character after the last update
Posted by: lukasF-7 | Date: 2023-01-25 10:30 | IP: IP Logged
Zdravím Vás,
tento problém mě trápí minimálně rok, napříč weby jsem řešil kolizní situace s menším či větším dopadem na spokojenost klienta. PSpad používám bezmála 10 let, bohužel tento problém mě nutí přejít k jinému editoru.
#25 Re: strange 俰؃ character after the last update
Posted by: rem17 | Date: 2024-04-16 14:01 | IP: IP Logged
Good day! Unfortunately, this bug has retured. I'm using version 5.0.7 (775) in the 64bit edition.
#26 Re: strange 俰؃ character after the last update
Posted by: pspad | Date: 2024-04-16 16:59 | IP: IP Logged
64b edition is experimental
#27 Re: strange 俰؃ character after the last update
Posted by: khagaroth | Date: 2024-04-21 08:37 | IP: IP Logged
That doesn't really matter. This bug was there long before the 64bit version even existed. This bug is probably already older than some of the users.
#28 Re: strange 俰؃ character after the last update
Posted by: rseibel | Date: 2024-04-22 10:13 | IP: IP Logged
This error exists since all versions after 5.0.4 (543) 32 bit.
Because there nothing happens, i changed to Rj TexEd last year.
#29 Re: strange 俰؃ character after the last update
Posted by: Alex | Date: 2026-03-03 01:28 | IP: IP Logged
Hi Jan. In recent time the problem happens too regularly. In some times/big files almost guarantee get this bug in some line on refreshing with ctrl+R
it also duplicate of this topics
forum.pspad.com
forum.pspad.com
I had 32b dev version 5.5.2
recently I back to 32b stable 5.5.1 (825), it seems this bug a bit rarer on that. but still present.
Edited 1 time(s). Last edit at 2026-03-03 01:29 by Alex.
