You are here: PSPad forum > Bug report / Hlášení chyb > Occur-Failure only (5.0.6. (579))
Posted by: Kawesi | Date: 2021-03-31 13:14 | IP: IP Logged
I wrote different http-links, each in a separate line.
Now i wanna COPY simply one of them. I mark this line at zhe beginning and pull to right.
The cursor runs right (highlighting) but ALL http lines lose their (blue) color to plain text like in a Block-COPY.
At Row 33 this behavior vanished and shows further the expected doing.
No data lost while COPY/PAST
Kawesi
5.0.6. (579)
at Windows 7
Posted by: pspad | Date: 2021-03-31 15:01 | IP: IP Logged
I tried to simulate it, but I wasn't sucessfull.
Can you make some screenshots?
I created new TXT file, put there about 80 HTTP links
I tried to select different parts of links, from the begin, from the end, select more lines, but I wasn't able to simulate it.
Posted by: Kawesi | Date: 2021-04-01 21:40 | IP: IP Logged
Hi Jan,
I've send you the requested screenshots via email. In the meanwhile the row number has changed to #38 (previously #33).
Maybe it's a failure of Win7 or while I use PSP not in full screen mode.
But I can live with it
Kawesi
PS: I found no way to link the JPGs to this reply.
Posted by: pspad | Date: 2021-04-02 04:55 | IP: IP Logged
This isn't bug.
When you select some text, PSPad highlights same text inside your file.
This is a reason, why it returns when you reach different text - column 38 in your file.
If you don't like it, switch it off in the program settings / Editor 2 - last option
Regarding links - you can upload it to any public image service, e.g. ctrlv.link
and put link here
Posted by: Kawesi | Date: 2021-04-02 12:07 | IP: IP Logged
I understand!
Sorry for the circumstances but I haven't seen this before 577.
-Kawesi-
Edited 1 time(s). Last edit at 2021-04-02 12:07 by Kawesi.
