You are here: PSPad forum > Bug report / Hlášení chyb > Erreur dans la différence de texte
Posted by: PYDou | Date: 2021-03-09 07:46 | IP: IP Logged
Dans la comparaison de 2 fichiers,
La ligne 145 est différente entre les 2 fichiers, mais cette différence s'affiche à la ligne 289 au lieu de 145
J'utilise la dernière version 5.0.5 (567) du 01-03-2021
PYDou
Posted by: pspad | Date: 2021-03-09 07:51 | IP: IP Logged
This problem in PSPad 64b version was fixed in 5.0.6, available here:
forum.pspad.com
Replace PSPad.exe only, it's enough.
Edited 1 time(s). Last edit at 2021-03-09 07:52 by pspad.
Posted by: Lolo Irie | Date: 2021-03-11 11:17 | IP: IP Logged
I've few issues with the compare features.
Spaces, blank lines are not always ignored (can't find why there are only few mistakes, but not with all blanks...). In the Compare parameters, I've checked all checkbox to ignore these.
More annoying, some real text differences are not found/highlighted.
You can view here:
imgur.com
I've tried with the last "official" 5.0.5 release (Install and Portable Versions), and tried now with the current developper 5.0.6 version.
Posted by: pspad | Date: 2021-03-11 13:12 | IP: IP Logged
Can you send me some test files please?
Posted by: Lolo Irie | Date: 2021-03-11 16:21 | IP: IP Logged
Sure.
Already thanks for your help !!!
Find here example files:
etalkers.org
Posted by: pspad | Date: 2021-03-11 16:30 | IP: IP Logged
I just tested it with 5.0.6 3ě and 64b version and I don't see any problem
PSPad shows 3 differences:
1. missing line 17
2. missing line 119
3. additional empty line before go
Ignore white space means spaces/tabs inside line, not a empty lines.
When I change any line and reload compare, there is reported line difference and on the bottom are 2 lines with marked difference
Edited 1 time(s). Last edit at 2021-03-11 16:32 by pspad.
Posted by: Lolo Irie | Date: 2021-03-12 07:40 | IP: IP Logged
ok really strange.
I've installed again a 5.0.6 release and it looks like it's working now.
Really sorry for the lost time here.
Big thanks (again) for "your baby" PSPAD and the support on this forum !!!
Posted by: pspad | Date: 2021-03-12 08:06 | IP: IP Logged
Thank you for info.
I am really glad it works for you.
There are some problems with cursor disappear in 5.0.6, fix will be available this weekend
