You are here: PSPad forum > Bug report / Hlášení chyb > Re: Error : Lost Saving Files
#1 Error : Lost Saving Files
Posted by: WildcatMidnight | Date: 2021-02-25 05:11 | IP: IP Logged
Hi
. I Create /or/ Open & Work with: More than 1 file(s) (At same time)
. I Finish all by: File-Exit /or/ Ctrl+Alt+F4 /or/ Left-Click_(Red)Window-Close-Button(Top-Right)
. Then PsPad shows Confirmation-Box: "Save Changes..."
. I choose (click): "Yes To All" (as many previous versions before / & like other apps familiar behavior)
. But this time - Version 5.0.4(543) - after checking my files: Only 1 file has been saved / & Other files has lost change (has been made)
Pls see it / Thanks
#2 Re: Error : Lost Saving Files
Posted by: pspad | Date: 2021-02-25 08:58 | IP: IP Logged
Thank you for report. As I remember, I fixed it in the current 5.0.5 build (PSPad developer forum), but please let me confirm it first.
Edited 1 time(s). Last edit at 2021-02-25 08:58 by pspad.
#3 Re: Error : Lost Saving Files
Posted by: pspad | Date: 2021-02-26 17:50 | IP: IP Logged
I can confirm, current 5.0.5 works fine and all files are saved
#4 Re: Error : Lost Saving Files
Posted by: WildcatMidnight | Date: 2021-03-01 04:10 | IP: IP Logged
Thanks
- Pls, make it (β5.0.5_Portable) Full-version (Install-able) soon.
Because now it has no (support) Recent/Jump-list(Windows) - that's inconvenient.
- Another problem is:
. PSPad can't show the blank-spaces at the end of each-line (if have some).
. In other words, it can't move to the end of line exactly (if there's one or more blank-spaces).
. If you press [End]_keyboard-button (at a line): PSPad always jumps just to right-after last visible-character (not-include blank-spaces). Therefore (you) don't know whether there's blank-space (or not) ; and how many (if have some) to edit/correct the line.
(In that case, (you) have to open the (same) file just at others some simple-plain text-editors (familiar-Notepad_e.g.) to jump & correct exactly.)
So, pls fix it.
Thanks smiling smiley Again
#5 Re: Error : Lost Saving Files
Posted by: pspad | Date: 2021-03-01 04:51 | IP: IP Logged
I hope I will prepare full version 5.0.5 it today winking smiley
#6 Re: Error : Lost Saving Files
Posted by: pspad | Date: 2021-03-01 04:59 | IP: IP Logged
Hello, to your bugs:
1. switch off Trim trailing spaces option in the program settings / Editor. If you have enabled enter behid Line of feed (EOL), there are no white spaces till you write any char. In the fact you put cursor into free space only.
2. I don't understand why I can't move to the end of line. Can you provide some example?
3. Behavior when you press ENTER depends of settings. Program settings / Editor 1 - switch off Auto indent mode option
If you want same behavior like Notepad, open program settings / Editor 1
switch off following options:
Scroll past EOF
Scroll past EOL
Auto indent mode
Extended Home key
Extended End key
