You are here: PSPad forum > Bug report / Hlášení chyb > Re: Color Scheme is not remembered (5.0.4 64b - 539)
Posted by: rbukovansky | Date: 2021-01-21 15:30 | IP: IP Logged
every time I select any color scheme and then click OK in Settings -> Program Settings -> Colors -> Color Scheme, then the color scheme is applied, but the selection is not remembered when I go back to the same setting, the selection in Color Scheme is gone.
Could you please check?
Thank you.
Richard Bukovansky
Posted by: pspad | Date: 2021-01-21 15:35 | IP: IP Logged
Empty scheme means don't change scheme.
Scheme is apllied and remembered
