You are here: PSPad forum > Bug report / Hlášení chyb > Installed v5.0.4 (540) and it doesnt display on Windows 10?
Posted by: Barton | Date: 2020-12-31 15:46 | IP: IP Logged
Downloaded the Installer version and when I launch PSPad, the wait icon displays, then stops, and nothing else happens. I check the Task Manager and see "Text editor (32 bit) in the "Background processes". Used PSPad for years, what's happened?
Thanks.
Posted by: pspad | Date: 2020-12-31 16:04 | IP: IP Logged
When you kill the process and start it again, will you see the same?
Posted by: nomad1 | Date: 2020-12-31 16:54 | IP: IP Logged
Yup, to samé. Nejde spustit. I když ukončím proces a spustím znovu. 539 funguje, 540 nikoli.
Edited 1 time(s). Last edit at 2020-12-31 16:55 by nomad1.
Posted by: pspad | Date: 2020-12-31 17:35 | IP: IP Logged
Hello guys
Please download portable version:
It should appear as PSpad 5.0.4 (541)
Can you test it please?
Posted by: pspad | Date: 2020-12-31 19:35 | IP: IP Logged
Because I am not able to simulate it, I need someone who can help me with testing.
Download current ZIP.
Unpack PSPad.exe + Language subfolder only, nothing else into separate folder out of program files
Run PSPad.exe from this folder.
Does it hangs?
PSPad stores it's config files in user profile: %appdata%\pspad
Delete (or rename) PSCache5.bin file from this folder.
Edited 1 time(s). Last edit at 2020-12-31 19:56 by pspad.
Posted by: Barton | Date: 2021-01-01 07:31 | IP: IP Logged
If I copy just the .exe and language folder, it works and displays the editor as expected.
For reference to the earlier install problem. When I end the task in the task manager for the full install and re-run the pspad.exe, the pspad.exe still hangs.
Thanks and Happy New Year!
Posted by: pspad | Date: 2021-01-01 07:39 | IP: IP Logged
Barton:If I copy just the .exe and language folder, it works and displays the editor as expected.For reference to the earlier install problem. When I end the task in the task manager for the full install and re-run the pspad.exe, the pspad.exe still hangs.
If you have little time, can you please extract whole portable version into some folder and run PSPad.exe from this folder?
If it will start, there is problem with old profile, try delete pscache5.bin file from the PSPad profile in %appdata%\PSPad
If it hangs, try to move out all DLL files in folder. If doesn't hang, return some files and test it.
Posted by: Barton | Date: 2021-01-01 20:34 | IP: IP Logged
I removed the previous installation last night (Revo Uninstaller). I freshly installed it from the installer (.exe) and it now launches as expected.
I realise that it doesn't really help you solve the original problem, sorry.
Edited 1 time(s). Last edit at 2021-01-01 20:37 by Barton.
Posted by: pspad | Date: 2021-01-01 20:41 | IP: IP Logged
Barton:I removed the previous installation last night (Revo Uninstaller). I freshly installed it from the installer (.exe) and it now launches as expected.I realise that it doesn't really help you solve the original problem, sorry.
Thank you for confirmstion
Posted by: Henk | Date: 2021-01-04 18:15 | IP: IP Logged
I had the exact same problem with the new v5.0.4 version as the original poster.
I installed the previous version v5.0.3 over it and everything works fine again.
I will wait for a newer version
