You are here: PSPad forum > Bug report / Hlášení chyb > Access Violation report - not sure if there is a specific email for this
#1 Access Violation report - not sure if there is a specific email for this
Posted by: Mikhail | Date: 2020-12-31 10:43 | IP: IP Logged
Exception description:
Selected open with pspad on a .txt file;
while this was starting up I selected another txt file and opened it with pspad.
Both files are less than 10kB
Using Ubuntu 18.04.5LTS 32 bit
Linux 5.4.0-58-generic i686
Only 2Gib ram and Pentium Dual CPU T2310 @ 1.46GHz
After selecting OK on first violation another one occurred - see below.
Access violation at address in module 'pspad.exe'. Read of address .
Exception class:
Exception address:
Stack list, generated 31/12/2020 10:12:37
Thank you for your time to report this issue!
Please don't post exception report into the forum.
Send it to my support address (see Help > About).
And please add a short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
- What did you do: ....<accurate step-by-step instructions here>..
- How did you do: by keyboard press, by menu, context menu, macro
- You had expected to get: ....
- But you got instead: .....
Thank you.
Program : Z:\home\mike2\snap\pspad\16\pspad\pspad.exe 5.0.3 (377)
System : Windows 7 Professional x32, Version: 6.1, Build: 1DB1, Service Pack 1
Processor: Intel, Intel(R) Pentium(R) Dual CPU T2310 @ 1.46GHz, 1460 MHz MMX
Display : 1440x900 pixels, 32 bpp PPI: 96
Active Controls Hierarchy:
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-28 13:45 by Stefan.
