You are here: PSPad forum > Bug report / Hlášení chyb > Re: Occurrences back
#1 Occurrences back
Posted by: Peter.eisentraeger | Date: 2020-08-06 08:27 | IP: IP Logged
I see the highlighted "occurrences back" in a smaller font than the other text. The longer the occurrence is the more obvious the effect is.
5.0.4 (515)
I would post a screenshot but is not forseen here.
#2 Re: Occurrences back
Posted by: pspad | Date: 2020-08-06 08:57 | IP: IP Logged
You can upload screenshot to any public picture service like ctrlv.cz
and place a link here
#3 Re: Occurrences back
Posted by: stanislav.mikusek | Date: 2021-01-03 22:33 | IP: IP Logged
I have the same problem,
I'm sending a screenshot to
ctrlv.cz
#4 Re: Occurrences back
Posted by: pspad | Date: 2021-01-04 04:17 | IP: IP Logged
What font do you use in the editor?
Is it current full version 5.0.4?
#5 Re: Occurrences back
Posted by: phampl | Date: 2021-01-21 18:38 | IP: IP Logged
When I use Courier, it is going back
when I use Courier New, it is OK
when I use fixedsys, it is going back
when i use Lucida console, it is going back.
Seems to me that it is using correct font, but the character spacing is smaller, one pixel between each two characters.
Při mojí angličtině ještě česky. Vypadá to, že se zmenšuje mezera mezi znaky, o jeden pixel mezi každými dvěma znaky proti normálu. U fontu Courier New, který tu mezeru má už malou, se to neděje.
32bit 5.0.4 full i dev(539)
#6 Re: Occurrences back
Posted by: pspad | Date: 2021-01-21 18:47 | IP: IP Logged
Courier, FixedSys, Lucida console are old fonts.
I will test it, but I suggest use of some modern fonts like Consolas
