You are here: PSPad forum > Bug report / Hlášení chyb > Re: right side line moving
#1 right side line moving
Posted by: LukasKriz | Date: 2020-07-24 10:36 | IP: IP Logged
On version 5.0.3 (maybe older) is not possible move right side line by clicking by the left mouse button at the ruler bar. On version 4.6.2 it was OK.
#2 Re: right side line moving
Posted by: pspad | Date: 2020-07-24 12:39 | IP: IP Logged
Just tested and it works like before.
Do you use high DPI?
I see there is a problem with first click only. As you click in the text, you can click on the ruller to move right border line
#3 Re: right side line moving
Posted by: pspad | Date: 2020-07-28 17:46 | IP: IP Logged
I found option what have incluence of it.
Please check program settings / Program 2:
Status bar functions require Double Click instead of Single click.
If checked, you will need dblClick to call statusbar functions or move right edge using ruller.
#4 Re: right side line moving
Posted by: LukasKriz | Date: 2020-08-25 11:44 | IP: IP Logged
Yes, it is it. I am apology for disturbing You.
#5 Re: right side line moving
Posted by: pspad | Date: 2020-08-25 11:59 | IP: IP Logged
It's not disturbing. I had to find it too grinning smiley
