You are here: PSPad forum > Bug report / Hlášení chyb > right side line moving
Posted by: LukasKriz | Date: 2020-07-24 10:36 | IP: IP Logged
On version 5.0.3 (maybe older) is not possible move right side line by clicking by the left mouse button at the ruler bar. On version 4.6.2 it was OK.
Posted by: pspad | Date: 2020-07-24 12:39 | IP: IP Logged
Just tested and it works like before.
Do you use high DPI?
I see there is a problem with first click only. As you click in the text, you can click on the ruller to move right border line
Posted by: pspad | Date: 2020-07-28 17:46 | IP: IP Logged
I found option what have incluence of it.
Please check program settings / Program 2:
Status bar functions require Double Click instead of Single click.
If checked, you will need dblClick to call statusbar functions or move right edge using ruller.
Posted by: LukasKriz | Date: 2020-08-25 11:44 | IP: IP Logged
Yes, it is it. I am apology for disturbing You.
Posted by: pspad | Date: 2020-08-25 11:59 | IP: IP Logged
It's not disturbing. I had to find it too
