You are here: PSPad forum > Bug report / Hlášení chyb > Re: access violation - happens more frecuently
#1 access violation - happens more frecuently
Posted by: Extranjero | Date: 2020-07-08 15:08 | IP: IP Logged
Exception description:
Access violation at address 0000000000808ABF in module 'PSPad.exe'. Read of address 00000000000000AD.
Exception address: 0000000000808ABF
Stack list, generated 8/7/2020 12:04:45
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : L:\aa-PORTABLEyLAUNCH\PROGS\ESENCIALES\PSPad\PSPad.exe 5.0.4 (511)
System : Windows 10 Professional x64, Version: 10.0, Build: 47BB,
Processor: Intel, Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz, 3000 MHz MMX
Skin : Carbon
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2020-07-09 18:25 by Stefan.
#2 Re: access violation - happens more frecuently
Posted by: pspad | Date: 2020-07-08 15:25 | IP: IP Logged
Please next time log to support mail.
I need to know when it occurs. What do you do when you see the exception.
I see you use Black theme
#3 Re: access violation - happens more frecuently
Posted by: Extranjero | Date: 2020-07-08 17:44 | IP: IP Logged
When I get this error, generally in the pspad-window all is frozen, was an 'exception' that I could copy the posted error-log.
So how to log to support mail?
I normally have 2 or 3 instances of PsPad running, in each of them 'created a project from folder'.
If the error occurs in one of the instances, the others are not affected.
One of the possibilities to reproduce the error (even it doesn't happen always) is to make some 'hard-changes' in the file-folder (eg. add, delete files with the windows explorer)
I don't think that the error is related to the Carbon theme, it also happened before - what happens is actually creating a new project, that there are changed folder files/contents more often, once the project enter in a more stable status with less changing files, file names etc. the error will happen less, I think ...
#4 Re: access violation - happens more frecuently
Posted by: Extranjero | Date: 2020-07-08 19:43 | IP: IP Logged
Note: Upcoming this error, all settings regarding to the skin in then PsPad.ini, and the 'special settings' are erased, and set back to the default settings.
#5 Re: access violation - happens more frecuently
Posted by: pspad | Date: 2020-07-09 03:41 | IP: IP Logged
There is still pspad.ini.bak in the folder
#6 Re: access violation - happens more frecuently
Posted by: syntech | Date: 2020-07-24 05:48 | IP: IP Logged
I also got this error, but I can't send the log because over the error window is another window with an OK button and the following text below, which pops up every time in a loop if I click on the OK button.
Access violation at address 006810C6 in module 'PSPad.exe'
Read of address 00000160
What I did? I wanted to switch to another file and clicked with the mouse on another tab. *error pops up*
PSPad is open since yesterday. Usually it's open a whole week, but because of issues with special characters and some Ini file changes (it's in another thread) I had to restart it. All I can do now is to kill the process.
#7 Re: access violation - happens more frecuently
Posted by: Andreas | Date: 2020-07-27 22:16 | IP: IP Logged
I also often get this error. I'm trying to save my session frequently so I wont loose my open files. Maybe one day Jan will find the error.
I am flirting with other editors more and more. There is one I might switch to.
Editor PSPad - freeware editor, © 2001 - 2020 Jan Fiala, Hosted by Webhosting TOJEONO.CZ, design by WebDesign PAY & SOFT, code Petr Dvořák, Privacy policy and GDPR
