You are here: PSPad forum > Bug report / Hlášení chyb > access violation - happens more frecuently
Posted by: Extranjero | Date: 2020-07-08 15:08 | IP: IP Logged
Exception description:
Access violation at address 0000000000808ABF in module 'PSPad.exe'. Read of address 00000000000000AD.
Exception address: 0000000000808ABF
Stack list, generated 8/7/2020 12:04:45
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : L:\aa-PORTABLEyLAUNCH\PROGS\ESENCIALES\PSPad\PSPad.exe 5.0.4 (511)
System : Windows 10 Professional x64, Version: 10.0, Build: 47BB,
Processor: Intel, Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz, 3000 MHz MMX
Skin : Carbon
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2020-07-09 18:25 by Stefan.
Posted by: pspad | Date: 2020-07-08 15:25 | IP: IP Logged
Please next time log to support mail.
I need to know when it occurs. What do you do when you see the exception.
I see you use Black theme
Posted by: Extranjero | Date: 2020-07-08 17:44 | IP: IP Logged
When I get this error, generally in the pspad-window all is frozen, was an 'exception' that I could copy the posted error-log.
So how to log to support mail?
I normally have 2 or 3 instances of PsPad running, in each of them 'created a project from folder'.
If the error occurs in one of the instances, the others are not affected.
One of the possibilities to reproduce the error (even it doesn't happen always) is to make some 'hard-changes' in the file-folder (eg. add, delete files with the windows explorer)
I don't think that the error is related to the Carbon theme, it also happened before - what happens is actually creating a new project, that there are changed folder files/contents more often, once the project enter in a more stable status with less changing files, file names etc. the error will happen less, I think ...
Posted by: Extranjero | Date: 2020-07-08 19:43 | IP: IP Logged
Note: Upcoming this error, all settings regarding to the skin in then PsPad.ini, and the 'special settings' are erased, and set back to the default settings.
Posted by: pspad | Date: 2020-07-09 03:41 | IP: IP Logged
There is still pspad.ini.bak in the folder
Posted by: syntech | Date: 2020-07-24 05:48 | IP: IP Logged
I also got this error, but I can't send the log because over the error window is another window with an OK button and the following text below, which pops up every time in a loop if I click on the OK button.
Access violation at address 006810C6 in module 'PSPad.exe'
Read of address 00000160
What I did? I wanted to switch to another file and clicked with the mouse on another tab. *error pops up*
PSPad is open since yesterday. Usually it's open a whole week, but because of issues with special characters and some Ini file changes (it's in another thread) I had to restart it. All I can do now is to kill the process.
Posted by: Andreas | Date: 2020-07-27 22:16 | IP: IP Logged
I also often get this error. I'm trying to save my session frequently so I wont loose my open files. Maybe one day Jan will find the error.
I am flirting with other editors more and more. There is one I might switch to.
Posted by: tfs | Date: 2021-06-15 13:46 | IP: IP Logged
I have had this problem for several years on Windows 7 computer. It appeared some time when I updated PSPad but the problem I saw only sometimes. After some time I updated PSPad again and the problem disappeared. I dodn't update PSPad anymore and everything was fine.
A few days ago I bought a new computer with Windows 10, installed a fresh version of PSPad and the problem is back. Now it appears every 5-10 minutes. I really like PSPad but I am thinking to switch to another editor because it's not possible to work in this way.
Exception address:
Stack list, generated 15/06/2021 14:29:55
Program : C:\Program Files\PSPad editor\PSPad.exe 5.0.6 (589)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i3-1005G1 CPU @ 1.20GHz, 1190 MHz MMX
Skin : Windows
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-09-10 06:31 by Stefan.
Posted by: tfs | Date: 2021-07-07 14:54 | IP: IP Logged
Is there a possibility to download the version 5.0.1? If yes, where? It was working fine but now PSPad is not usable.
Access violation errors + strange characters in the file appears after saving it, like:
ÿ se
Posted by: pspad | Date: 2021-07-07 15:51 | IP: IP Logged
tfs:Is there a possibility to download the version 5.0.1? If yes, where? It was working fine but now PSPad is not usable.Access violation errors + strange characters in the file appears after saving it, like:
All older version are avaiůlable on FossHub, there is older version tab:
