You are here: PSPad forum > Bug report / Hlášení chyb > PSPad unicode 5.0.4 (509) save icon fault
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.4 (509) save icon fault
Posted by: ramdem | Date: 2020-06-20 10:47 | IP: IP Logged
PSPad 5.0.4(509) 32 byte
Clicking active File save icon on toolbar, Not working.
Best Regards
#2 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: pspad | Date: 2020-06-20 12:06 | IP: IP Logged
I am sorry, but I don't understand what "is not working".
File isn't saved? You got any message?
#3 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: ramdem | Date: 2020-06-20 22:00 | IP: IP Logged
File is not saving. Icon stayed at active position. With icon submenu file can save. But direct clicking to icon file didn't save. No message seen.
Edited 1 time(s). Last edit at 2020-06-20 22:01 by ramdem.
#4 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: pspad | Date: 2020-06-21 08:08 | IP: IP Logged
I tried to simulate it but I wasn't able to do it.
Is your file in any synchronized folder (One drive, Gogle drive)?
Isn't your file R/O?
Does PSpad show any meessage?
Ctrl+S does save your file or not?
#5 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: ramdem | Date: 2020-06-21 10:29 | IP: IP Logged
I tried;
I changed toolbar icon set to "PSPad classic" It saved file.
and turned back "PSPad".
Now icon behaves normal operation.
It is very strange.
Answers to your questions
*File is a local file.
* not in read only mode
* PSPad doesn't show message
* ctrl+s saves file
Sincerely
#6 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: ramdem | Date: 2020-06-21 15:08 | IP: IP Logged
I'm using windows 10 x64 laptop.
If Toolbar Icon set "PSPad" selected, second and third icon with arrows calculation incorrect (open and save icons shown condensed in first part of image).
After editing document save icon is expanding and print icon is disappering.(in last part of image). Also if you click leftside of icon document can save not clicking center
As seen image second part In silk toolbar icon set layout and behaviour is correct.
Also in PSPad 5.0.3 with PsPad icon set toolbar layout correct and function okey.
Not serious but it is a strange problem,
Sincerely
Edited 1 time(s). Last edit at 2020-06-21 15:14 by ramdem.
#7 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: pspad | Date: 2020-06-21 18:06 | IP: IP Logged
What is your screen resolution? Do you use some high DPI settings, e.g. 150% in the screen settings?
#8 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: pspad | Date: 2020-06-21 18:26 | IP: IP Logged
I found problem when Project toolbar is hidden. Now I am able to simulate it.
#9 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: ramdem | Date: 2020-06-21 18:30 | IP: IP Logged
resolution is 1366*768 and size 100% as recommended.
#10 Re: PSPad unicode 5.0.4 (509) save icon fault
Posted by: pspad | Date: 2020-06-21 18:41 | IP: IP Logged
I found a problem and fix it. As temporary solution you can make project toolbar visible or copy .\Skin\PSPad.bmp to e.g. PSPad_temp.bmp and choose it in the program settings as toolbar icon set.
Goto Page: 1 2 Next
