You are here: PSPad forum > Bug report / Hlášení chyb > offline server causes project to freeze
#1 offline server causes project to freeze
Posted by: gwinkless | Date: 2020-03-26 09:42 | IP: IP Logged
Hi
One file in a project I had open was on a smb share that went offline. I wasn't editing that file but it was open (unchanged) in an editor window.
PSpad freezes for several seconds at a time - I assume because it's trying to check the modified-time of that file.
Is there any way you could do the file-time checks in a separate thread? Or perhaps add a shorter timeout?
Cheers
#2 Re: offline server causes project to freeze
Posted by: pspad | Date: 2020-03-26 09:55 | IP: IP Logged
Hello. Thete isn't timeout its simple call of Windows API
I will try to move it into thread, but it will bring complication - if you close file before thread ends e.t.c
