You are here: PSPad forum > Bug report / Hlášení chyb > support@pspad.com offline?
Posted by: Kawesi | Date: 2020-03-04 23:54 | IP: IP Logged
After sending an "Err Log" to the adress above:
A message that you sent could not be delivered to one or more of
its recipients. This is a permanent error. The following address(es)
failed:
support@pspad.com
host: a.mx.pspad.com (81.0.235.44) reason: 550 sorry, permanent envelope failure (#5.7.1)
-Kawesi-
Edited 1 time(s). Last edit at 2020-03-04 23:59 by Kawesi.
Posted by: pspad | Date: 2020-03-05 04:47 | IP: IP Logged
Thank you for info, I will let hosting check it.
Edited 1 time(s). Last edit at 2020-03-05 06:37 by pspad.
Posted by: Kawesi | Date: 2020-03-06 19:34 | IP: IP Logged
Problem identified.
My server (1&1) isn't able to send eMails correctly.
Gmail does it!
Thanx Jan...
-Kawesi-
Posted by: pspad | Date: 2020-03-06 19:54 | IP: IP Logged
I will wait for my hosting reply
Posted by: pspad | Date: 2020-03-07 18:15 | IP: IP Logged
Webhosting replay:
Sender's mail server is on several blacklists, this is reason, why mails are blocked.
Posted by: Kawesi | Date: 2020-03-10 17:50 | IP: IP Logged
Thanx for replying
It seem that server 1&1 is at more blacklists cause declaires (more or less hidden), that it can't send mails to Outlook recipients.
What a blame for a million user server.
-Kawesi-
