You are here: PSPad forum > Bug report / Hlášení chyb > Re: Ftp Manager
Re: Ftp Manager
#1 Ftp Manager
Posted by: Mystral77 | Date: 2020-02-24 08:45 | IP: IP Logged
Here are some problems I have in the FTP Connexion Manager in the version 5.0.3(377) :
1) Folders : not in rapid drop-down list
I'm using PSPad and SFtp sometimes to see log files.
I can create a folder in the FTP Manager, but when I click on the little drop-down arrow of the FTP manager, I can't see the folders, only a list of hosts.
2) Folders : create before use
If I create a folder before adding a host, the folder does not appear in the drop-down list for "Add to folder" ...
3) Folders : modification
Is there a way to modify a folder name in the FTP Manager ?
4) Connexion : no way to rename a connexion
If I rename a connexion, I have always the error : "The connexion "xxxxxx"
still exists" (in my case in french : "La connexion "xxxxxx" existe déjà !")
Thank you and sorry for my bad english.
Best regards
Edited 2 time(s). Last edit at 2020-02-24 08:47 by Mystral77.
#2 Re: Ftp Manager
Posted by: pspad | Date: 2020-02-24 09:02 | IP: IP Logged
Thank you for feedback.
#3 Re: Ftp Manager
Posted by: pspad | Date: 2020-02-25 13:32 | IP: IP Logged
Except the point 2 will be part of next build.
When you creates folder in advance, it isn't part of any connection. Possibility to create folder allows you drag/drop connection into folder and between folders.
