You are here: PSPad forum > Bug report / Hlášení chyb > PSPad blocked
PSPad blocked
#1 PSPad blocked
Posted by: Kawesi | Date: 2020-01-08 15:16 | IP: IP Logged
Sometimes when I wanna create a "New File", the NewFile-Window open exactly behind the main PSP window.
Normally I use "Stay on Top" and so PSPad is blocked. The only way out is to "kill" PSPad via task manager and restart.
-Kawesi-
#2 Re: PSPad blocked
Posted by: pspad | Date: 2020-01-08 15:59 | IP: IP Logged
Thank you for report, I will check it.
#3 Re: PSPad blocked
Posted by: pspad | Date: 2020-01-08 17:48 | IP: IP Logged
Anyway, if it will happen to you, simple press ESC key. Cause NewFile form is focused, it will close it up and you can continue work.
#4 Re: PSPad blocked
Posted by: pspad | Date: 2020-01-08 19:51 | IP: IP Logged
Fixed. Wait for next developer build
#5 Re: PSPad blocked
Posted by: Kawesi | Date: 2020-01-10 21:42 | IP: IP Logged
Many Thanx, also for the ESC hint.
-Kawesi-
#6 Re: PSPad blocked
Posted by: pspad | Date: 2020-01-10 21:48 | IP: IP Logged
Download latest developer build
#7 Re: PSPad blocked
Posted by: Kawesi | Date: 2020-01-19 23:09 | IP: IP Logged
After install 503b I found my Settings smashed. So I restored them from a 502-backup and have now the same circumstances. Popup-Windows (Settings, Highlighters etc.) are not longer topper than top but behind the Main-Window.
Ok! No Prob. ESC-Button is further the best choice. smiling smiley
-Kawesi-
#8 Re: PSPad blocked
Posted by: pspad | Date: 2020-01-20 05:13 | IP: IP Logged
Hello.
I know there is a problem in the last build. It's fixed already. Wait for new build please
#9 Re: PSPad blocked
Posted by: pspad | Date: 2020-01-20 10:32 | IP: IP Logged
Build (367) with stayontop fix was published
