You are here: PSPad forum > Bug report / Hlášení chyb > PsPad 502 339/341 (64b): Application Error
#1 PsPad 502 339/341 (64b): Application Error
Posted by: HPie | Date: 2019-11-14 21:32 | IP: IP Logged
Since version 339, when leaving PsPad 64b following error message is displayed:
Exception EAccessViolation in module PsPad.exe at 000000000011E499.
Access violation at address 00000000001E499 in module 'PsPad.exe'. Read of address 0000000700000000.
#2 Re: PsPad 502 339/341 (64b): Application Error
Posted by: pspad | Date: 2019-11-15 05:19 | IP: IP Logged
Hello. I need to know what file type you are working with, what functionality you use...
#3 Re: PsPad 502 339/341 (64b): Application Error
Posted by: HPie | Date: 2019-11-15 13:52 | IP: IP Logged
The problem already occurs by opening and closing the editor, no matter if a file was still opened or not.
When you start the editor without a file, a "new.txt" is opened. If you close right now the editor, the error message will be displayed. No matter if you've closed or not the opened file.
If you open a second file before closing the editor, then no error message will be displayed, but only in this case. No matter the file type you've opened. First new message can be edited and saved with a new extension.
#4 Re: PsPad 502 339/341 (64b): Application Error
Posted by: pspad | Date: 2019-11-15 16:44 | IP: IP Logged
Thank you for clarifying
#5 Re: PsPad 502 339/341 (64b): Application Error
Posted by: pspad | Date: 2019-11-15 19:16 | IP: IP Logged
Can you send me please your PSPad.ini to support e-mail? I tried to simulate it but I am not able to get error.
Maybe it's some setting specified and your settings could help me find a problem.
