You are here: PSPad forum > Bug report / Hlášení chyb > Re: Search words and files open window without anything after .net 4.7.2 update
Posted by: mmartins888 | Date: 2019-08-01 16:41 | IP: IP Logged
After .net 4.7.2 update, the PSPad 5.0.1 started having a wrong behavior when searching for words or files, resulting in a window without anything, not showing the resulting list.
Do you have a solution?
Posted by: pspad | Date: 2019-08-01 17:31 | IP: IP Logged
PSPad doesn't use. Net framework.
Please check search parameters, e.g. search for open files.
Screenshot with search params should be helpful too
