You are here: PSPad forum > Bug report / Hlášení chyb > Re: Some unicode glyphs not displaed depending on context
Posted by: bolfh | Date: 2019-06-30 13:35 | IP: IP Logged
copy / paste this text to PSPad:
- snip -
U+24BD "H inside a circle" not displayed: Ⓗ
Two U+24BD "H inside a circle" not displayed: ⒽⒽ
U+24BD "H inside a circle" displayed: Ⓗ①
- snip -
The first two lines show only boxes instead of Ⓗ, only the third line shows Ⓗ (and ①).
Oliver
Posted by: pspad | Date: 2019-06-30 14:11 | IP: IP Logged
Ensure, you use the unicode font for the PSPad.
Menu Format/Font. Try Consolas font.
Posted by: bolfh | Date: 2019-06-30 14:57 | IP: IP Logged
of course I used fonts capable of displaying the glyph (Consolas among them), else it wouldn't show up in the third line.
The interesting part is that on my Windows 10 PC, it depends on the other characters present in the context, as I wrote in the subject.
But after your reply I tried another PC running Windows 7. On this system, the H never showed up.
Some Latin-D characters are not displayed on both systems: ꜦꜧꜨꜩꜲꜳꝎ
Oliver
