You are here: PSPad forum > Bug report / Hlášení chyb > Re: Block toolbar icons
Posted by: Gabriel_ACE | Date: 2019-06-14 12:43 | IP: IP Logged
please , I need an option that freezer toolbar icon position
because soo many times when I change windos size all icons changed it's position, that freak me out
ups post in a wrong place, sorry
Edited 1 time(s). Last edit at 2019-06-14 12:45 by Gabriel_ACE.
Posted by: pspad | Date: 2019-06-14 15:59 | IP: IP Logged
Position of toolbar section is given.
You can switch off unused sections in the View menu
Posted by: Gabriel_ACE | Date: 2019-06-14 17:16 | IP: IP Logged
pspad:Position of toolbar section is given.
my problem is a little bit different
all the icons that I have visible in the bar I give them use
but when I change the window of the maximized state to restored, the program moves the bars and accommodates them in a second level (while it is in that state it is perfect)
but when I return to put the window maximized, the bars that went down 1 level do not go back to its previous position removing space on the screen
for example (you can open it to see better) :
maximized windows
restored windows
maximized windows (again)
see???
Posted by: pspad | Date: 2019-06-14 17:21 | IP: IP Logged
There isn't enough space to show toolbars in one line.
Posted by: Gabriel_ACE | Date: 2019-06-18 12:31 | IP: IP Logged
pspad:There isn't enough space to show toolbars in one line.
yes thats right (when windows is restore state), but when I maximized windows, the icons don't fix its position
Posted by: pspad | Date: 2019-06-18 12:56 | IP: IP Logged
When I maximize window, it reorders panels and all panels should be in one line.
Posted by: Gabriel_ACE | Date: 2019-06-19 12:28 | IP: IP Logged
pspad:When I maximize window, it reorders panels and all panels should be in one line.
That is what is not happening!!!
irregularly does not that
can you check it, please?
