You are here: PSPad forum > Bug report / Hlášení chyb > Re: encoding wrong detcted on large files
#1 encoding wrong detcted on large files
Posted by: JoKalliauer | Date: 2019-04-28 17:48 | IP: IP Logged
If I open this file homepage.boku.ac.at (https://homepage.boku.ac.at/jokalliauer/Internet/Bug.svg ) PsPad detects "ANSI Western European (1252)", but it is UTF-8-encoded.
But, however if I open this file homepage.boku.ac.at (https://homepage.boku.ac.at/jokalliauer/Internet/NoBug.svg ) PsPad detects "Unicode UTF-8 no BOM (65001)".
The file starts with `<?xml version="1.0" encoding="UTF-8"?>`, therfore encoding should be clear.
#2 Re: encoding wrong detcted on large files
Posted by: pspad | Date: 2019-04-28 18:03 | IP: IP Logged
PSPad uses for autodetection first about 10k of text. Because in your file is encoded image and few UTF-8 encoded chars is on the end, PSpad won't detect it.
Try to put some UTF-8 encoded chars before image.
Header information isn't relevat for autodetection, PSpad isn't not a web browser who intepret code content.
You can anytime change code page in the menu Encoding to UTF-8 and reload file (Ctrl+R)
If you have enabled save file state options, PSPad will remember code page for this file for you.
#3 Re: encoding wrong detcted on large files
Posted by: JoKalliauer | Date: 2019-04-29 15:19 | IP: IP Logged
Thank you for your fast answer!
PSpad is an lightweight editor that can edit SVG-files from 1MB-1GB, but I do not know if there are any special Unicode-characters in the file (since I only manipulate them marginally) and I would like to open svgs per default as UTF-8.
add unicode-character:
Since I am processing many svg-files (mostly UTF-8) on wikimedia-commons, which should be reuploaded, changing content (f.e. add a comment) just because of a very uncommon software-problem (Inkscape, Illustrator, notepad++, common Browsers,... do no not have this problem) is undesirable.
PSPad recognises file-types (highlighting), therfore I would like to change default coding according to the file-type. (SVGs are almost always UTF-8, even old ones.)
If this is not implemented:
How can I change the default encoding for all files to open? (I do not want any autodetection at all.)
#4 Re: encoding wrong detcted on large files
Posted by: pspad | Date: 2019-04-29 15:25 | IP: IP Logged
Program settings / files
There is default CP
You can use project, where you can specify CP too.
#5 Re: encoding wrong detcted on large files
Posted by: Andreas | Date: 2019-04-29 15:41 | IP: IP Logged
I have no problem opening your first linked file. It shows UTF-8 no BOM.
Here are my settings:
- format for new files: UNIX
- standard code page: UTF-8 no BOM
Toolbar settings:
- Coding: UTF-8 no BOM
- Coding: auto coding - deactivated
- Format: UNIX
If you test this consider that if you once have opened a file and pspad shows an unwanted codepage, that pspad saves this somewhere. So when you test my settings you allways have to test with a new file. To do this you can e.g. use a copy of your file.
ps I think the UNIX setting is irrelevant, is just for the completeness.
#6 Re: encoding wrong detcted on large files
Posted by: Andreas | Date: 2019-04-29 15:44 | IP: IP Logged
There is default CP...
This will not work if auto detect coding is activated. With auto detect his file shows ANSI anyway.
