You are here: PSPad forum > Bug report / Hlášení chyb > Error and fewer functions (HEX editor)
Goto Page: 1 2 Next
#1 Error and fewer functions (HEX editor)
Posted by: jpietras | Date: 2019-02-12 06:19 | IP: IP Logged
An attempt to copy a fragment from a binary file.
After which the application turns off.
It is turned off every time, the error is repetitive 100 by 100.
Quote:
Access violation at address 77A135CE in module 'ntdll.dll'. Read of address 00300030.
Quote:
Exception description:
Exception address:
Stack list, generated 12/02/2019 07:09:05
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
When selecting the hex value, it no longer shows their value or the length of the selected fragment on the lower bar.
Please, improve the Hex editor because can not use it at this time.
Edited 1 time(s). Last edit at 2019-06-07 18:45 by Stefan.
#2 Re: Error and fewer functions (HEX editor)
Posted by: pspad | Date: 2019-02-12 07:58 | IP: IP Logged
Your PSPad version?
Please send me log into support mail, there is a chance I will be able localize problem from it.
#3 Re: Error and fewer functions (HEX editor)
Posted by: jpietras | Date: 2019-02-12 08:24 | IP: IP Logged
Version: 5.0.0 (277)
When you try to send "Mail log" the application turns off.
I also noticed that when selecting a larger area and adding it to the clipboard, the application freezes or immediately turns off without reporting an error. Also locks the clipboard.
#4 Re: Error and fewer functions (HEX editor)
Posted by: pspad | Date: 2019-02-12 08:28 | IP: IP Logged
Please visit developer forum, download current build 5.0.1 and replace existing files. There is few HEX editor related bugs fixed already.
There is a Copy button on the exception dialog what allows you copy log content to clipboard.
To be able send error log directly using your e-mail klient, your e-mail client have to support simple mapi protocol. In the program settings / Internet should be set your default e-mail client, if not, choose it.
#5 Re: Error and fewer functions (HEX editor)
Posted by: jpietras | Date: 2019-02-12 10:12 | IP: IP Logged
For version 5.0.1 it is the same.
It is very difficult to capture the error window in this version. It is frozen all the time or immediately closes. Once a window of error appeared, but it also froze.
imgur.com
#6 Re: Error and fewer functions (HEX editor)
Posted by: pspad | Date: 2019-02-16 17:46 | IP: IP Logged
on 14th Feb. I uploaded new build. Copy/Paste from HEX editor was changed and it works for me, include information on the status bar
#7 Re: Error and fewer functions (HEX editor)
Posted by: jpietras | Date: 2019-02-18 06:25 | IP: IP Logged
It's better but there are still errors.
I do not see any information on the bottom bar. :(
When Paste hex from another file:
"is not a valid integer value"
Quote:
Exception class: EConvertError
Exception address: 00428F4E
Stack list, generated 18/02/2019 07:17:01
[00428F49] System.SysUtils.ConvertErrorFmt +
[0042A49C] System.SysUtils.StrToInt + C
[0074882F] MPHexEditorEx.TMPHexEditorEx.CBPaste (Line 1391, "MPHexEditorEx.pas" + 8) + D
[009AC28E] uMain.TfPSPad.aPasteExecute (Line 5488, "uMain.pas" + 21) + $F
[009BC6B4] uMain.TfPSPad.ActionListExecute (Line 11245, "uMain.pas" + 11) +
[00547EAC] System.Actions.TContainedActionList.ExecuteAction +
[00409B26] System.@CallDynaInst +
[0054AD3D] Vcl.ActnList.TCustomAction.Execute +
[004D8DB7] System.Classes.TBasicActionLink.Execute +
[0067084F] Vcl.Menus.TMenuItem.Click +
[006724B7] Vcl.Menus.DoClick + $EF
[006725A3] Vcl.Menus.TMenu.IsShortCut +
[0068BFBC] Vcl.Controls.TWinControl.IsMenuKey +
[0068C031] Vcl.Controls.TWinControl.CNKeyDown + D
[006850E2] Vcl.Controls.TControl.WndProc + BE
[00689B97] Vcl.Controls.TWinControl.WndProc + B
[00689164] Vcl.Controls.TWinControl.MainWndProc + C
[004D9CA4] System.Classes.StdWndProc +
[006595B0] Vcl.Forms.TApplication.IsKeyMsg +
[0065951B] Vcl.Forms.TApplication.IsMDIMsg + F
[0065985B] Vcl.Forms.TApplication.ProcessMessage + $CF
[006598C2] Vcl.Forms.TApplication.HandleMessage + $A
[00659BF5] Vcl.Forms.TApplication.Run + $C9
[009E7A9C] PSPad.PSPad (Line 98, "PSPad.dpr" + 40) +
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.1 (310)
System : Windows 10 Professional x64, Version: 10.0, Build: 4563,
Processor: Intel, Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz, 2900 MHz MMX
Display : 1920x1200 pixels, 32 bpp
Active Controls Hierarchy:
TMPHexEditorEx ""
TfChildHexa "fChildHex_D5048502"
#8 Re: Error and fewer functions (HEX editor)
Posted by: jpietras | Date: 2019-02-18 09:03 | IP: IP Logged
I also noticed that it distorts the copied hex fragment.
Quote:
04000000D94500021E0000004500030D00000081000606000000A8000003000000CC05000003000000CC01000003000000CC0D000000CC000040000000D9000002000000D900014D696573746F2045504F202020202020
to:
Quote:
04000000554500021E0000004500030D00000081000606000000A800000300000049050000030000004901000003000000490D00000049000040000000550000020000005500014D696573746F2045504F202020202020
#9 Re: Error and fewer functions (HEX editor)
Posted by: pspad | Date: 2019-02-18 12:17 | IP: IP Logged
I tested it but I am not able to simulate it.
I pasted what I copied.
32b or 64b PSPad?
#10 Re: Error and fewer functions (HEX editor)
Posted by: jpietras | Date: 2019-02-18 12:53 | IP: IP Logged
using 32b
Goto Page: 1 2 Next
