You are here: PSPad forum > Bug report / Hlášení chyb > PSPad crash (access vioation)
#1 PSPad crash (access vioation)
Posted by: idefix2 | Date: 2019-01-31 17:49 | IP: IP Logged
On the disk, the file I edited had been changed by another program.
After that, in PSPad, I clicked the close file button in the upper right corner of the edit window of the file.
I got the message File has been changed, and was asked if I want to reload the file to see the changes.
I clicked yes, and got this access violation, obviously pspad tried to load the file into a document instance that it already closed.
Error log:
Exception address:
Stack list, generated 31.01.2019 18:37:16
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\PSPad\PSPad.exe 4.5.9 (2600)
System : Windows 8 Professional x64, Version: 6.2, Build: 23F0,
Processor: Intel, Intel(R) Xeon(R) CPU E3-1270 V2 @ 3.50GHz, 3490 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Due to a configuration problem of my mail, sending the error log from within PSPad does not work, so I post it here.
Edited 1 time(s). Last edit at 2019-03-19 10:40 by Stefan.
