You are here: PSPad forum > Bug report / Hlášení chyb > "Error saving file" on windows 10
Posted by: emilianofeijoo | Date: 2018-12-17 22:31 | IP: IP Logged
Hi all,
I have a problem with my pspad app using in Windows 10.
When I tried to save some changes inside my .txt file, throws a message "Error saving file emiliano.txt".
First at all, I copied this file ... and open again with another name (maybe the file was corrupted) but happens the same behavior few chances later.
I check the permissions and are okay.
If I open the same file with notepad and save it, doesn't appear the problem.
Maybe some issue with the PSPad app?
What do you think? This kind of issue sounds knowledge?
Thanks in advance to all!
Emiliano
Posted by: pspad | Date: 2018-12-18 05:43 | IP: IP Logged
Isn't your folder "synchronized"? E.g. Google drive, One drive... ?
PSpad does few steps when saving file, not simple save as Notepad only.
Posted by: emilianofeijoo | Date: 2018-12-18 15:09 | IP: IP Logged
Hi and thanks for your answer,
Yes, I have installed and running Google Drive and in this folder is synchronizing, because is important for me to have always a backup of this documents.
Have some parameter to skip this error in Pspad and still using Google Drive?
Thanks in advance again.
Emiliano
Posted by: pspad | Date: 2018-12-18 18:55 | IP: IP Logged
Open program settings / press Direct edit button (bottom)
Change value of the variable SafeFileSave from 0 to 1
This settings should help you to solve your problem.
Edited 1 time(s). Last edit at 2018-12-18 18:55 by pspad.
Posted by: emilianofeijoo | Date: 2018-12-18 22:29 | IP: IP Logged
Thanks,
Now I can save my files without problems.
Thanks a lot for your support.
Regards.
Emiliano
Posted by: Yesead | Date: 2019-02-12 16:54 | IP: IP Logged
I had the same problem like emilianofeijoo, but now everything looks fine and files are being saved without any problem.
