You are here: PSPad forum > Bug report / Hlášení chyb > Tracking the garbage bug
#1 Tracking the garbage bug
Posted by: tmtisfree | Date: 2018-12-10 12:02 | IP: IP Logged
Hi Jan,
Still here sad smiley
I had about 25 files opened, and this time it was inserted in 2 different files right after I was changing the default code page (with the menu) of some newly opened files.
Not sure it that will helped you much.
Cheers,
TMTisFree
Edited 2 time(s). Last edit at 2018-12-10 12:03 by tmtisfree.
#2 Re: Tracking the garbage bug
Posted by: tmtisfree | Date: 2018-12-10 15:22 | IP: IP Logged
Looking closely at the garbage, there are many html tags which I never work with, like
<h6>
for ex.
Doing a search on files, the only place on this PC where I find the
<h6>
tag is in the template file "HTML.DEF".
I use mostly the CSS/Javascript/PHP/HTML multi syntax highlighters.
Hope this will help.
#3 Re: Tracking the garbage bug
Posted by: Vany | Date: 2018-12-10 16:35 | IP: IP Logged
and what if you change all the templates used in multi-hiliter to UTF-8 ?
#4 Re: Tracking the garbage bug
Posted by: tmtisfree | Date: 2018-12-10 17:10 | IP: IP Logged
Will do that.
Most probably the culprit is the HTML multihighlighter: the newly opened files was a mix of HTML, JS and PHP, and the HTML multihighlighter was on.
#5 Re: Tracking the garbage bug
Posted by: tmtisfree | Date: 2018-12-16 15:33 | IP: IP Logged
I revert changing the codepage as clips (which I don't use) did not work after that, and that did not change anything about random garbage insertion anyway, as new ones have now appeared, for ex.:
Edited 1 time(s). Last edit at 2018-12-16 15:33 by tmtisfree.
