You are here: PSPad forum > Bug report / Hlášení chyb > Code explorer window for COBOL missing some paragraph names
Posted by: mdn8rdr | Date: 2018-12-06 18:36 | IP: IP Logged
It appears that if a paragraph name starts with certain reserved words, it is not recognized as a paragraph name.
Examples not appearing in Code Explorer:
END-OF-JOB.
CONTINUE-HERE.
Examples appearing in Code Explorer:
ENX-OF-JOB.
XONTINUE-HERE.
I am running 5.0.0 (277)
Thanks!
Posted by: Gabriel_ACE | Date: 2018-12-14 17:48 | IP: IP Logged
wow! I never see thats O_O
Posted by: pspad | Date: 2018-12-15 15:06 | IP: IP Logged
mdn8rdr:It appears that if a paragraph name starts with certain reserved words, it is not recognized as a paragraph name.Examples not appearing in Code Explorer:
END-OF-JOB.CONTINUE-HERE.
ENX-OF-JOB.XONTINUE-HERE.
Thanks!
I need to recognize end of the section. END-OF- CONTINUE-
I know you don't want to see in code explorer end of the section. But how can I recognize it when you misspeled it?
It's not a problem of the PSPad, but it's problem in source code
Posted by: Gabriel_ACE | Date: 2018-12-17 13:25 | IP: IP Logged
pspad:mdn8rdr:It appears that if a paragraph name starts with certain reserved words, it is not recognized as a paragraph name.Examples not appearing in Code Explorer:
Thanks!
cases 1:
only by colum position..... if the source code use standar colum position (colum a , b)
perform use dot (".") , like
continue.
continue-exit. exit.
case 2:
continue it is used on this context
if A
continue
else
do something
end-if
the word is clear, without more characters
I never see for example
if A
continue.
thats doesn't have logic
Best Regards!
Posted by: pspad | Date: 2018-12-17 13:48 | IP: IP Logged
Forum destroys source code indentation.
Can you send me some source sample to mail with description whats wrong?
I am not Cobol programmer.
Posted by: Gabriel_ACE | Date: 2018-12-17 15:49 | IP: IP Logged
pspad:HelloForum destroys source code indentation.
DONE!
Posted by: pspad | Date: 2018-12-17 18:01 | IP: IP Logged
Gabriel_ACE:pspad:HelloForum destroys source code indentation.
I am not Cobol programmer.DONE!
As mail attachment please. Mail body destrois it too.
Posted by: Gabriel_ACE | Date: 2018-12-18 13:31 | IP: IP Logged
hahahahaha
DONE AGAIN!
