You are here: PSPad forum > Bug report / Hlášení chyb > Re: wrong read codepages
#1 wrong read codepages
Posted by: Jacenty_K | Date: 2018-07-16 10:58 | IP: IP Logged
I write program in CP852
But in version 5.0.0 (277) if I setting codepage 1 (OEM) or codepage 852 in the project, The Files are opened as ANSI :(. Program are not get setting about current code page in project.
Regards
Jacek
#2 Re: wrong read codepages
Posted by: pspad | Date: 2018-07-16 13:50 | IP: IP Logged
If your files doesn't contains accented chars, there is no difference between ANSI and OEM. TEXT files doesn't contains any code page identification. PSpad "guess" code page counting siginificant characters.
You can anytime change code page - select OEM and reload file (Ctrl+R)
If you enable file status saving (Program settings / Files), PSpad will remember code page for each file.
You can use PSPad project and for your project set default code page for new files in project settings.
