You are here: PSPad forum > Bug report / Hlášení chyb > Bug with aHTMLSelTag and with Log window in v4.6.1
#1 Bug with aHTMLSelTag and with Log window in v4.6.1
Posted by: Texter | Date: 2016-07-07 19:03 | IP: IP Logged
Hello!
1. When I run aHTMLSelTag, the program hangs and crashes. It happens when opened tag is like < div> or <div > or in both cases and problem may occure with closing tag.
Currently I'm writing a plugin EditText github.com which has some nice text editing enhancements ...and I want to make "Goto Matching Tag" feature which is based on aHTMLSelTag.
2. When I run
Quote:
Command Line
(aCmdWindow) and check
Quote:
Run under MS-Dos command interpreter
and
Quote:
Capture Program Output Window
, I see small window result. Previous version doesn't have this problem. If you need I can send you screenshots.
P.s.:
Could you give me a hint on how to execute selected text and send result back to Log window?
Thanks!
Best, Regards.
