You are here: PSPad forum > Bug report / Hlášení chyb > Access violation while comparing files
#1 Access violation while comparing files
Posted by: OrxataEnFartons | Date: 2016-04-26 12:21 | IP: IP Logged
I have a file A and I want to compare it with B, C, D, etc. I do it sequentially, keeping A open and closing the other files after the comparison results. But from time to time, when trying to open a file -let's say F- to compare, the program crashes. It doesn't depend on the file trying to open, and if I terminate and launch the program again, I can compare A and F with no problem.
Furthermore, if I press the 'Mail log' button, I get a popup with a Index is out of range message.
Exception description:
Access violation at address in module '.exe'. Read of address .
Exception address:
Stack list, generated 26/04/2016 14:14:47
Thank you for your support!
Nobody here is interested in such long logs.
(See forum.pspad.com)
Also please describe what you have done right before
and how often that error occurs.
Thanks
Program : C:\Program Files\PSPad editor\PSPad.exe 4.6.0 (2700)
System : Windows 10 Professional x32, Version: 6.2, Build: 23F0,
Processor: Intel, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3500 MHz MMX
Display : 1680x1050 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2016-05-29 16:43 by Stefan.
