You are here: PSPad forum > Bug report / Hlášení chyb > Autosave main window position
#1 Autosave main window position
Posted by: roybishop | Date: 2016-02-12 21:25 | IP: IP Logged
..is not working. I have it checked in Settings/Program Settings.../Program (part 2) but each time I reopen PsPad it is the middle of the screen. Moving it/minimizing/restoring it, closing it with Ctrl key or Shift key does not remember a new windows position or size.
Version 4.6.0, Windows 10 Pro 64 bit
#2 Re: Autosave main window position
Posted by: pspad | Date: 2016-02-13 07:26 | IP: IP Logged
I guess you installed PSPad as portable into program files or you unpacked zip there. In this case PSpaad has no right to write into config.
You have 2 ways how to fix it:
1. Run PSPad installer again and uncheck option "Portable application" during setup.
2. Run PSPad as administrator (use right mouse) to elevate PSpad rights, go to Program settings/System and check Multiuser environment
Your previous setting will be preserverd.
You don't need any special action to remember windows size and position, PSPad do it automatically as default.
