You are here: PSPad forum > Bug report / Hlášení chyb > Re: Problems with charset
#1 Problems with charset
Posted by: toto | Date: 2016-02-04 06:36 | IP: IP Logged
I just upgrated to version 4.6 (2700) from 4.5.9 (2600) where I got problems with the charset.
After the Upgrate I opened a PHP file with FTP And saved it over ftp. I don't changed anything at the charset. After upload all € signs are resplaced with ? signs.
When I downgrated I found another issue ;)
4.5.9 working
HTML code: content="text/html; charset=iso-8859-1"
PSPad: Format=ISO 8859-2
-> € works in the browser
4.5.9 not working
HTML code: content="text/html; charset=iso-8859-2"
-> € invisible in the browser
4.6 not working
HTML code: content="text/html; charset=iso-8859-1" or iso-8859-2
-> instead of € a ? is visible in the browser
When I was switching the Format (UTF-8, OEM) in PSPad to find the failure and saving over FTP, PSPad changed all my € signs into ? in my PHP files angry smiley A warning like : "not all signs could be saved in this format" will be fine ;) (if this is not another failure grinning smiley)
greetings
Thorsten
#2 Re: Problems with charset
Posted by: pspad | Date: 2016-02-04 06:53 | IP: IP Logged
When you open your file, do you see chars correctly, include '€' ?
When you open your file, check code page on the statusbar.
In your FTP connection settings, is there binary transfer type? If not, FTP server manipulates with text file content.
#3 Re: Problems with charset
Posted by: Freeman | Date: 2016-02-06 23:16 | IP: IP Logged
ISO-8859-1 nor ISO-8859-2 doesn't contain the euro sign. Use ISO-8859-15 or Windows-1252 instead.
#4 Re: Problems with charset
Posted by: toto | Date: 2016-02-07 08:56 | IP: IP Logged
both are not available in PSPad ;) But good to know, I will try it
Edit: Only Windows-1252 AND iso-8859-1 works (PSPad 4.5.9)
Edited 1 time(s). Last edit at 2016-02-07 09:03 by toto.
#5 Re: Problems with charset
Posted by: toto | Date: 2016-02-07 09:53 | IP: IP Logged
in PSPad 4.5.9 AND 4.6 yes
4.5.9 AND 4.6 iso-8859-2
yes binary
tried another update to 4.6
always ? insted of € with all charsets in HTML + PSPad
Then I switches to tuf-8 in HTML and PSPad and it works.
Like Freeman wrote it's ok when it's not working ;) Perhabs iso-8859-1 works because of a workaround of Chrome???
greetings
Thorsten
#6 Re: Problems with charset
Posted by: toto | Date: 2016-02-07 10:19 | IP: IP Logged
OK UTF-8 is fine but the text in my Database (MySQL) is another format (PHPMyAdmin says UTF-8 Grrrrrr) so I downgrated to 4.5.9 and changed all back. I think this is my problem winking smiley
NEW PROBLEM:
I changed the PHP File in 4.6 to iso-8859-2 and saved it with FTP. All Fine in 4.6. Downgrade to 4.5.9 and all € are switched to ? !!! 4.5.9 say iso-8859-2.
I think 4.6 saves in a differtend charset then 4.5.9 ...
