You are here: PSPad forum > Bug report / Hlášení chyb > Windows 10: screenshot in taskbar / alt-tab previews
#1 Windows 10: screenshot in taskbar / alt-tab previews
Posted by: mkchris | Date: 2016-01-10 11:38 | IP: IP Logged
This is only very minor, but after upgrading to Windows 10, the screenshot for PSPad in the taskbar and also when using alt-tab always shows a dialog box, rather than the actual PSPad screen, even if there's no dialog box open at all - as far as I can tell, it's the last dialog box that was open.
I've not noticed this with any other applications. I'm using version 4.6.0 (2700)
Thanks.
Edited 2 time(s). Last edit at 2016-01-10 11:40 by mkchris.
#2 Re: Windows 10: screenshot in taskbar / alt-tab previews
Posted by: pspad | Date: 2016-01-10 13:19 | IP: IP Logged
Maybe it's caused old development stuio version. But taskbar screenshot is made by Windows itself, not by program. Program has no influence of it.
#3 Re: Windows 10: screenshot in taskbar / alt-tab previews
Posted by: dtowell | Date: 2016-02-11 17:33 | IP: IP Logged
Yes, W10 does the work but it does so by monitoring the application (possibly what messages or their responses) to decide when/how to take snapshots. There is almost certainly something PSPad can do to affect it, and it would be appreciated.
#4 Re: Windows 10: screenshot in taskbar / alt-tab previews
Posted by: froschi | Date: 2016-02-22 12:33 | IP: IP Logged
bug confirmed.
also when using alt-tab.
#5 Re: Windows 10: screenshot in taskbar / alt-tab previews
Posted by: pspad | Date: 2016-02-22 12:37 | IP: IP Logged
It's a PSPad bug or Windows BUG? Application doesn't make any snapshots. It's operating system business.
Maybe move to new IDE version will solve it.
#6 Re: Windows 10: screenshot in taskbar / alt-tab previews
Posted by: Andreas | Date: 2016-02-22 20:24 | IP: IP Logged
I also have seen a dialog box some times ago. At present my alt tab preview is ok. Windows 10. But I'm also using '7+ Taskbar Tweaker' rammichael.com because Win10 taskbar behaviour is very annoying.
Edited 1 time(s). Last edit at 2016-02-22 20:28 by Andreas.
