You are here: PSPad forum > Bug report / Hlášení chyb > PSPAD 4.6.1. (2703) Compiling a file stopped working with Windows 10
Posted by: syntech | Date: 2015-12-17 15:42 | IP: IP Logged
I had to upgrade my Win 7 PC to Win 10 and since that I cannot compile a source file anymore. Maybe someone can help, please?
Here's the error from the log window in PSPAD:
0 [main] make 8868 _cygtls::handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
First I thought it might be a 32/64bit Problem, but all Processes from PSPAD over CMD to Cygwin\bin\make.exe are 32 bit processes, so I don't expect this to be the problem.
I've also set \Cygwin\bin\make.exe and bash.exe to Windows 7 compatibility mode, but that doesn't work either. I also tried to use different cmd.exe (32 and 64bit), also without success. I'm running out of ideas... :(
Here are the compiler setting I'm using in PSPAD: (mind that they worked well in Windows 7)
Compiler: cmd.exe
param: /C C:\dev86.bat & make -j 6 "%Name%.o"
start dir: %Dir%
log-file: %Dir%\make.log
Log Parser: %F(%L):*
PS: dev86.bat is called to set some environment variables
PPS: Windows 10 was installed as upgrade, so all old programs were kept
Posted by: syntech | Date: 2015-12-22 15:05 | IP: IP Logged
NVM, it's working again.
