You are here: PSPad forum > Bug report / Hlášení chyb > Regex replace with group capture and substitution not working
#1 Regex replace with group capture and substitution not working
Posted by: therium | Date: 2015-11-18 13:18 | IP: IP Logged
PSPad 4.5.8 (2482) on Windows 7.
I want to replace about 50 footnotes with a different format.
Old format: 1 <#cn1>. blah blah blah
New format: [^1]: blah blah blah
So I selected 2 lines to test the replace on. I did a replace with regex and tried to capture the footnote number. It didn't work. In the replace box, the '\1' is supposed to represent the digits captured in the search box. The screen capture below changes all footnotes to the number one.
imgur.com
Edited 2 time(s). Last edit at 2015-11-18 13:20 by therium.
#2 Re: Regex replace with group capture and substitution not working
Posted by: pspad | Date: 2015-11-18 15:42 | IP: IP Logged
For substitution use $1, not a \1
See the PSPad help (press F1 in find/replace fialog) for the regular expression examples
#3 Re: Regex replace with group capture and substitution not working
Posted by: therium | Date: 2015-11-22 13:35 | IP: IP Logged
Super! Thank you.
