You are here: PSPad forum > Bug report / Hlášení chyb > The use of the undo function loss data when use ALT-select
#1 The use of the undo function loss data when use ALT-select
Posted by: wiko | Date: 2015-07-15 13:58 | IP: IP Logged
Steps to reproduce (version used: 4.5.9 (2600)):
use ALT sets Column Mode (Program Settings Editor (Part 1)
use real Tabs (Program Settings Editor (Part 2)
- start PSPad
- type some lines startet with blanks
- type some lines startet with tabs
- make ALT-select to delete leading blanks
the result is not what you think, because in lines with leading TABs some characters deleted.
- use the undo function
the result is not the previous contents.
