You are here: PSPad forum > Bug report / Hlášení chyb > 'Documentary comments' field limit too small
Posted by: toralf | Date: 2015-04-02 09:33 | IP: IP Logged
The field for "Documentary comments" in Highlighter Setting only allows 2 characters. Is that correct?
The help file states that you could e.g. use "@ToDo". So I think it should allow more characters.
The same field in the User Highlighter Definition allows for more characters.
Posted by: pspad | Date: 2015-04-02 10:08 | IP: IP Logged
I will fix it.
