You are here: PSPad forum > Bug report / Hlášení chyb > Re: Find/Replace multifiles with wrong find-text
Posted by: Macari | Date: 2015-03-17 14:40 | IP: IP Logged
Hello.
This bug is very old, but maybe you can fix it. ;)
Select in text a word like "abcdefg" and make a find/replace for mutlifiles. Search it. Now select the same word but only "abc" and start find/replace again. You can see in search field "abcdefg" instead of "abc".
Hope you can understand what I mean.
Posted by: sw | Date: 2015-04-22 15:27 | IP: IP Logged
Also,
if
- you searched before for a lowercase word (say "text")
- and now you select the same word but uppercase ("TEXT")
- and open the "search /Replace in Files..." dialog
then
- in the "Text to Find:" field you will find the lowercase word ("text") instead of the selected uppercase one.
PSPad 4.5.9 (2600)
Windows 7 Ultimate sp1 32-bit.
Posted by: pspad | Date: 2015-05-19 11:02 | IP: IP Logged
I hope both problems are fixed. Wait for the next build.
