You are here: PSPad forum > Bug report / Hlášení chyb > bug when loading from command line (build 2507)
#1 bug when loading from command line (build 2507)
Posted by: Gorlash | Date: 2014-10-08 18:02 | IP: IP Logged
I was in the following directory:
C:\Microsoft SDKs\Windows\v7.0\Include
and tried to open an existing file there, called x.txt
What I got was two empty files:
c:\Microsoft
SDKs\Windows\v7.0\Include\x.txt
Looks like you had an issue with the embedded space!!
BTW, If I drag-and-drop from Explorer, this opens just fine.
#2 Re: bug when loading from command line (build 2507)
Posted by: pspad | Date: 2014-10-09 04:43 | IP: IP Logged
How did you open this file? What was you command?
#3 Re: bug when loading from command line (build 2507)
Posted by: Gorlash | Date: 2014-10-09 14:38 | IP: IP Logged
my typed command was "pspad x.txt"
#4 Re: bug when loading from command line (build 2507) - nevermind
Posted by: Gorlash | Date: 2014-10-09 17:05 | IP: IP Logged
Okay, I somehow ended up with the wrong "build 2507"... even though it was saying that build in the About dialog...
I just downloaded the package from the development-builds page, extracted it into PsPad directory, and I am no longer having this problem (nor the other loading problem).
yawning smiley
Sorry about this confusion...
